Warrior Minis schon bekannt? 4WD/MiniZ Bodies sollen passen
BeitragVerfasst am: 22.10.2011, 00:15    Titel: Warrior Minis schon bekannt? 4WD/MiniZ Bodies sollen passen Antworten mit Zitat
http://www.bigsquidrc.com/warrior-minis/
If you’ve been thinking about getting into mini and micro scale cars, be sure to check out the new Warrior line of cars. These little guys are fully RTR with a 2.4 GHz radio system, separate ESC with reverse, full time 4wd, a full set of ball bearings, and a ball differential. A LiFe battery and charger is also included. It’s also said that a Kyosho Mini-Z body will drop right on without modification. In the USA you’ll find these things being distributed by Sun Trade LTD
Bildmaterial: Bigsquidrc
