tor
Anmeldedatum: 19.12.2005 Beiträge: 5
Verfasst am: 19.12.2005, 11:57 Titel: X-Trek Pro (English Question) |
This is the only forum i have found that has some sort of info on the X-Trek Pro so i hope its ok with an english question.
I´m new to micro cars but know my way around tech stuff.
-Is it possible to do annything about the servo stuttering or better signal?
-Is it possible to get oppgrade parts and such?
Best Regars
Tor
Merry Xmas  |
tor
Verfasst am: 19.12.2005, 12:14 Titel: Re: X-Trek Pro (English Question) |
Wow, that was a quick answer, thank you.
Do i open the servo or is it just the gears outside of the servo?
I Read that some one had changed some resistors on the PCB, annyone know annything about this?
Tor |
Verfasst am: 19.12.2005, 12:48 Titel: Re: X-Trek Pro (English Question) |
Yes, you have to open the servo to lube the gears.
Another solution for the stuttering-problem:
- Change the servo-motor (follow the link to find some pics)
Spitfire suggest to change the servomotor to a less powerfull one, e.g. a Microsizers MicroBee 2.2 or 2.6.
Ixarus uses a Penracer motor. This motor has a higher internal resistance. So it might help, if you solder a 10 or 20 Ohm resistor to the original motor.
tor
Verfasst am: 19.12.2005, 13:13 Titel: Re: X-Trek Pro (English Question) |
Do you have anny links for some shops where i can order parts and motors?
Tor |
tor
Verfasst am: 19.12.2005, 20:48 Titel: Re: X-Trek Pro (English Question) |
Problem solved, i greased the gears and put on a new antenna (cat 5 cable) and both cars works great now.
almost no servo stutter and double the recieve range.
Tor |
fefe RC-Fan
Anmeldedatum: 04.09.2005 Beiträge: 150
Verfasst am: 20.12.2005, 17:31 Titel: Re: X-Trek Pro (English Question) |
Where are you (tor) from?
Came you from England?
Can you speak german or you can speak
only egnlish?
Life you in Germany?
fefe _________________ Keine Macht den Sonntagsfahrern |
Verfasst am: 20.12.2005, 17:53 Titel: Re: X-Trek Pro (English Question) |
@ fefe
If you had taken a closer look at Tor's eMail-adress, you would have noticed that he might be from Norway... So i conclued that his German is even worse than your English. (Correct me, if I'm wrong, Tor)
Nevertheless, your questions are really offtopic. Why don't you simply ask Tor himself via PN?
tor
Verfasst am: 20.12.2005, 21:01 Titel: Re: X-Trek Pro (English Question) |
I’m from Norway, and my German sucks. I have been using translating programs to read these posts , and they don’t work to well.
As you say this is of topic, but thank you for the interest.
Tor
