epoxy RC-Fan
Verfasst am: 05.04.2008, 18:56 Titel: digiQ zinn rolle rebuild |
moved from rettet eure digiQ's. (going off topic there)
it figures that i have to work with the amount of katalyst.
the instructions from hobbytime were not very clear in
deutsch, nederlands or english unfortunatly.
basic idea:
i doubt if i am the first, but maybe the first to try to make moulds of this type, you see, i havn't a centrifugal machine to do it the profi way, i'm interested to know what results can be made with this "lowtec" solution.
also making a "rolle" in one part is almost impossible,
i should stop trying to reinvent the wheel.
but seeing this result from a failed mould,
and inspite of making a mess, having fun making it,
i did have some test pieces that showed much more detail.
i'll be up for the 2nd try.
epoxy RC-Fan
Verfasst am: 05.04.2008, 19:05 Titel: Re: digiQ zinn rolle rebuild |
getting closer.
not perfect yet, but not a bad result without a gussmachine.
i'dd like to make some different wheels too,
maybe a wheel with spokes or holes in them ?
to be continued.
dela Moderator
Verfasst am: 05.04.2008, 19:27 Titel: Re: digiQ zinn rolle rebuild |
"epoxy going selfmademan". Very well done!
Die sehen nicht schlechter aus als damals die schweren Laufrollen für Digiqs von robokalle. Das ist Modellbau!
btw: wollte ich nicht mal eine Tiger aus Silber gießen? Egal, die 100 g Silber, die ich seitdem im Keller liegen habe, dürften heute ein Vermögen wert sein.
epoxy RC-Fan
knacki RC-Enthusiast
Verfasst am: 05.04.2008, 23:36 Titel: Re: digiQ zinn rolle rebuild |
It looks that you finally found a solution.
Starting to be the "Digi-Q Micro Tank top tuner ?":D
Freut mich, wenn meine Anregungen zu so guten Ergebnissen führen.
Gruß,
Knacki |
epoxy RC-Fan
dela Moderator
epoxy RC-Fan
Verfasst am: 06.04.2008, 13:23 Titel: Re: digiQ zinn rolle rebuild |
the music is pretty bad, it just happened to be on the radio
when i was recording.
i'm truly sorry about that.
maybe next time i'll play my heino collection ?  |
Meltdown
Anmeldedatum: 02.04.2007 Beiträge: 21
Verfasst am: 07.04.2008, 02:48 Titel: Re: digiQ zinn rolle rebuild |
That's looking quite good!
Excellent!
A persistent man will get it right in the end
Where did you get the silicon rubber?
Was it expensive?
The video is hilarious.
The music is too, lol
Heino?
Please have mercy, please you're killing me man, lol  _________________ Bin Hollander, spreche nur Bahnhof
Visit my website!
http://www.tachyonmusic.com
epoxy RC-Fan
Verfasst am: 07.04.2008, 13:36 Titel: Re: digiQ zinn rolle rebuild |
hi meltdown.
it worked pretty well, thank you.
though i would rate robokalle's rolle as excellent,
they are much more precise.
but mine are not so bad thinking it came out of
a simple can.
[darf ich werbung machen ?]
the cheapest i found so far is from a Ebay.de store
called "troll factory".
i would not call the red silicone very expensive,
but i'll have to see howlong the moulds will last.
and how about those "slapstick" type of special effects,
i'll bet i tricked you all.
epoxy RC-Fan
Verfasst am: 04.05.2008, 23:07 Titel: Re: digiQ zinn rolle rebuild |
o.k. maybe i didn't fool you at all.
i've been fooling around a little more.
the details came out pretty nice, but they are difficult
to make. |
Verfasst am: 05.05.2008, 00:07 Titel: Re: digiQ zinn rolle rebuild |
Applaus  |
dela Moderator
Verfasst am: 05.05.2008, 00:35 Titel: Re: digiQ zinn rolle rebuild |
Wirklich eine hervorragende Arbeit! Wenn ich daran denke, daß du vor kurzem noch nach den alten Zinnrollen gesucht hast: jetzt bist du der Meister!
Absolut klasse! Beide Daumen hoch!
Dany_the_kid RC-Fan
Verfasst am: 05.05.2008, 15:57 Titel: Re: digiQ zinn rolle rebuild |
nice
Kann man damit auch AWD-Achsschenkel, oder so was in der Grösse, nachgiessen? Woraus ist die Form, womit wird gegossen, und wo kann man das kaufen, und wie stabil ist das.
Verfasst am: 05.05.2008, 16:18 Titel: Re: digiQ zinn rolle rebuild |
Zinn wird hier gegossen, wie der Titel sagt.
Form ist aus Silikon
von Hobbytime, im übrigen auch unter den Links unter Werkstoffe zu finden
Hier habe ich noch etwas gefunden. In günstigen, kleineren (15Eus=500gr.) Gebinden:
Silikon fürs Zinngießen
"Kurzfristig hitzebeständig bis ca.400 - 450 Grad Celsius"
Edit:
Heißer?
Aluminium, Bronze etc mit Formsand
Gugge ma da
Meltdown
Verfasst am: 05.05.2008, 18:12 Titel: Re: digiQ zinn rolle rebuild |
Wow Top man!
Very nice work! _________________ Bin Hollander, spreche nur Bahnhof
Visit my website!
http://www.tachyonmusic.com |
epoxy RC-Fan
Verfasst am: 06.05.2008, 00:52 Titel: Re: digiQ zinn rolle rebuild |
@ all, thanks for the kind replies, it helps.
@knacki, thanks for the translation.
Quote: Kann man damit auch AWD-Achsschenkel, oder so was in der Grösse, nachgiessen?
wow, maybe knackifish translation could also help here. a steering knuckle ?
many small things could be made this way, but Zinn is not a realy strong metal, it can only take so much before it bends and breaks.
so far i'm basicly only using them as balancing weights.
but in the microRC range it could have some use because the forces used are usually micro too.
Quote: Woraus ist die Form, womit wird gegossen, und wo kann man das kaufen, und wie stabil ist das.
knacki is right, the trollfactory is a good place to buy this silicone.
don't buy it from some dusty shelf in a backward store,
the silicone has a one year "shelf life". !!
i must say, i'm cheating on the zinn mix here,
it's not realy reinzinn at all.
i'll try DIN style reinzinn next weekend and see how that goes.
bronze is very heiß.
and also expensive to work with.
casting aluminium can be done with ease,
but it's pretty dangerous and very toxic,
better read up on safety precautions before trying that.
keep you posted.
haegar69 RC-Enthusiast
Verfasst am: 06.05.2008, 09:04 Titel: Re: digiQ zinn rolle rebuild |
Nice work and very impressive!! But unfortunately i sold all my DigiQs...
@Dany: Zinn ist zu weich und ist für deine Knuckles mit Sicherheit nicht benutzbar. _________________ Suche dauerhaft Overland Klein- /Ersatzteile |
Dany_the_kid RC-Fan
Verfasst am: 06.05.2008, 09:41 Titel: Re: digiQ zinn rolle rebuild |
HI,
Yes, I ment the steering knuckles.
I try to copy the knuckles I made for my AWD Trial-stick because the milling is very costly and takes a long time. Casting may be faster, if it works. (partly translated with babelfish, noch knackifisch)
epoxy RC-Fan
